MOM_TCL error while running CMM simulation
1. NX version - 10.0.3.5
2. MACHINE : selfmade 3-axis gantry CMM
3. Error log:
Event Handler: C:\Siemens\NX10\cmm_inspection\resource\postprocessor\cmm_dmis_plugin.tcl
Event: MOM_SIM_execute_nc_command
Error Info: can't read "DATA(INITIALIZATION)": no such element in array
    while executing
"if {$DATA(INITIALIZATION) == 0}  { SIM_end_of_simulation }  else  {
        if [catch { parse_ncline $mom_sim_nc_command } result ]  {
            glo..."
    (procedure "MOM_SIM_execute_nc_command" line 18)
    invoked from within
Error Code: NONE
Our team recently started to use the Inspection Programming module and encountered such a problem. Initially we used a model of a similar CMM which we got from supplier. Then we replaced this model with our own leaving the original kinematics, after which this error began to appear. The error occurs after starting the simulation of the inspection program.
Could you help us determine how to fix this error?
