MOM_display_message
In NX9 there is a new MOM-command:
For example:
    MOM_display_message "There is an error !!!" "Errortitle" "I" "OK" "Return" "Exit"
How do I get the return-value 1, 2 or 3, depending which button is clicked?
Thank's for help
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
Re: MOM_display_message
You can use something like this:
global return_value
set return_value  [MOM_display_message "Select machine" "Select Machine" Q Alpha-T21iL Alpha-T21i]
Best Regards,
Great! This is what I did but I forgot to set the variable global.
Thank's a lot
Werner
