Re: MP(Maintenance Pack) output
4th try (sorry Smiley Frustrated)
try this :
if {[gets [open $outputFile r]] == {} } {
 exec "[MOM_ask_env_var UGII_ROOT_DIR]\\env_print.exe" -n >$outputFile
instead of
if { [file exists $outputFile] == 0} {
with 'exec' , the file is automatically created even if command is empty
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Why so difficultly?
set patch_version [string trim [MOM_ask_env_var NX_PATCH]]
MOM_output_literal ";*********** patch_version = $patch_version *************"
You will get:
;*********** patch_version = NX 10.0.3.5 MP12, 15Dec16.  See Maintenance Pack letter for detailed list of fixes. *************
Additional a string-trim function and you have what you want.
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
NX_PATCH is not a standard NX environment variable, but a custom one. It might have been set through a batch file used to start NX at your site.
Production: NX12.0.2, VERICUT 8.2, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 11.4
Development: C (ITK), .NET, Tcl/Tk Testing: NX (1876) | AWC 3.4 Preparing: -
Thank you mkn...That worked!
Kal.
NX 9.0.3.4 MP12 | PB 9.0.3.2 | NX11.0.2.7 MP13 | PB 11.0.2 | VERICUT 7.3.4
Hello.
Just got NX 11.0.2.7 MP2 installed and started testing.  When posting in NX11, it no longer shows the correct NX Version...for some reason it shows NX 9.0.3.4 MP12?
Read online that UGII_ROOT_DIR has been obsoleted in NX11...if true...what has it been replaced with?
What can I need  to fix the cc so it works for NX11?  Will the fix still work for previous versions (show correct version for NX9)?
O0001 (xxxxxxxxxxxxx)
(MACHINE      : xxxxxxxxxxxxxxxxxxxxx)
(PROGRAMMER   : KAL G.)
(DATE         : TUE, OCT 17, 2017 05:07PM)
(NX VERSION   : NX 9.0.3.4 MP12)
(NX POST DATE : THU, SEP 07, 2017 04:06PM )
Thanks.
Kal.
replace with :
%UGII_BASE_DIR%\NXBIN
there may be a better solution , I will do this :
if {[file exists $env(UGII_BASE_DIR)/NXBIN] } {
... Do Something
} else {
... Do Something
Hope que ça help
www.adgroupe.com
Hello MKN.
I couldn't get this to work; reported it to GTAC & it's been PR'd by development.
Thanks for your help.
Kal.
Hello.
Worked w/ GTAC & CAM development, solution below is what worked for us.
Kal.
global mom_ug_version
if { $mom_ug_version == "NX 10.0.3.5" || $mom_ug_version == "NX 9.0.3.4" || $mom_ug_version == "NX 8.5.0.23" || $mom_ug_version == "NX 7.5.5.4" || $mom_ug_version == "NX 6.0.5.3"} {
  exec "[MOM_ask_env_var UGII_ROOT_DIR]\\env_print.exe" -m >$outputFile
  } else {
exec "[MOM_ask_env_var UGII_BASE_DIR]\\NXBIN\\env_print.exe" -m >$outputFile
   if { [gets [open $outputFile r]] == {} } {
     exec "[MOM_ask_env_var UGII_BASE_DIR]\\NXBIN\\env_print.exe" -n >$outputFile
Another ENV that should work (instead of mom_ug_version):
UGII_VERSION
I'm on NX10, and the value is "v10".
I believe in tcl ths would be
global env
set test $env(UGII_VERSION)
Might save you if the wrong MR is installed ;-)
The following is much simpler and works with any MR or MP.
	scan [string trim [MOM_ask_env_var UGII_VERSION]] "v%d" ugii_version
	if { $ugii_version < 11 } {
	} else {
Have fun Smiley Wink
