MRL tool library revise id
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Hi all,
I have a question for you.
Is possible to manage the tool revise id during the tool export from MRL library?
I would like to retrieve only the last tool revise released.
Re: MRL tool library revise id
So to make sure I understand correctly...
You want the latest released revision, not the latest un-released revision?
What you are trying to do is to limit the tools in the Library-Search-Result to one specific revision instead of listing all revisions of the tool.
This is possible in NX 10.0.3 using the Customer Defaults “Filter Search Result Revisions”.
You can configure the revision rule by using the “Assembly Load Options”.
You will find additional details in the attached document “NX_CAM_retrieve_tool_revisions.docx”.
