Machine code simulation collision error in Turning
Hi all,
I am doing a project on machine code simulation in turning 2 axis.  configured in machine tool builder.  When i run the program in tool path simulation , it is working correctly. In machine code simulation, the axes are moving away from the work coordinate system and moves beyond the Machine zero position.  shows axis violation message.
The work coordinate system is not updating in machine code simulation.
Pls find the video file, support to solve the issue.
