Machine tool Builder Problem: Can not define Kinematic Chain
Hello
I have been trying to Define Kinematic Chain in NX 10.
Some reason Defining Kinematic chain in NX10 machine tool builder,
i am not able to select any linear axis or PART and so on....
Any Ideas what is wrong??
All axis are defined and model works well in NC code simulation.
But I need to limit its kinematic chain to 4 axis machine.
Re: Machine tool Builder Problem: Can not define Kinematic Chain
Make sure you have the kinematics components on the TOOL end classified as _DEVICE and POCKET otherwise these branch will no taken into account for chain definition.
SPINDLE -> _DEVICE
  |--POCKET  -->DYNAMIC_HOLDER
You can compare with the examples shipped with NX.
Thomas Schulz
Siemens PLM
Thanks Thomas
Missing piece was PART_MOUNT_JCT, After Defining this Worked well.
Jussi
