Machine tool run time....
I am trying to output the length of time per machine tool.  I believe I want to use the mom_sys_tool_time command but I keep getting errors saying that the variable doesn't exist even if I declare it in the beginning of my custom command.  I've had trouble with _sys variables before so I think I might be misusing it.  Does anybody have any experience with this?
Re: Machine tool run time....
mom_toolpath_time is the entire time for the current operation including rapid moves.
mom_toolpath_cutting_time contains only the cutting time of the current operation.
You will have to sum up the times for each tool manually.
When I look in the MOM Variables Browser I don't see either of those variables listed.  Should I expect them to?  I'm in NX 10.
The variables browser is not up-to-date, it is just an average to get a feeling for the naming.
The best you can do is to run the review tool when generating shop documentation or post-processing a small sample tool path.
@JarvisIntern wrote:
Here is an old custom command from Hank Holt that should give you a good start.
Save it as pb_cmd_machine_times.tcl, and import in to your post.
# Exported Custom Commands created by holt
# on Wed Feb 05 16:11:49 2003 Central Daylight Time
proc PB_CMD_start_time { } {
global accumulated_time
set accumulated_time 0
proc PB_CMD_path_time { } {
# add the custom command PB_CMD_start_time to
# the Start_of_Program event, then add
# this custom command to the End_of_Operation event
# This will calculate the time for each path and output it
global mom_machine_time accumulated_time mom_operation_name
global mom_sys_control_in mom_sys_control_out ci co
# call in the control in & out codes
set ci " "
set co " "
if {[info exists mom_sys_control_in] == 1 }  { set ci $mom_sys_control_in }
if {[info exists mom_sys_control_out] == 1 }  { set co $mom_sys_control_out }
set op_time [expr $mom_machine_time - $accumulated_time]
MOM_set_seq_off
MOM_output_literal "$co==========================================$ci"
MOM_output_literal "$co OPERATION: $mom_operation_name   TIME: [format "%3.1f" $op_time] MIN.$ci"
MOM_set_seq_on
set accumulated_time $mom_machine_time
proc PB_CMD_machine_time { } {
global mom_machine_time ci co
MOM_set_seq_off
MOM_output_literal "$co ========================================== $ci"
MOM_output_literal "$co TOTAL TIME: [format "%3.1f" $mom_machine_time] $ci"
MOM_set_seq_on
Thanks to all,
All of this has been very useful.
