MachineConfigurator 1.0.0.909 issue
I have an issue with de Machine Configurator upgrade.
I have uninstall the old version.
I have install SPLM License Server Version 8.0.
And I have install MachineConfigurator 1.0.0.909.
But i can´t make it work.
When i try to open the app the proceess stop here:
Thanks for your answer,
Ivan
Re: MachineConfigurator 1.0.0.909 issue
Do you get any further message, or does the system looks like it hangs with the 'splash'-Screen?
Do you have used admin rights when installing the machine configurator?
Thomas Schulz
Siemens PLM
Hi!
I do the instalation with admin rigths.
And does not appear any message, if you look the Manager task the process begin but immediately disappears.
Ivan
It is needed to have the VS2013 32-bit Redistributable package from Microsoft installed.
Please download that from Microsoft page, install and test again.
Note: Don't use the 64 bit verion.
Sorry for the inconvenience
Thomas Schulz
Siemens PLM
Hi Thomas,
It works now!
Thank you!
Best regards
Ivan
