Maching Bearing Groove With T-Cutter
I am trying to use a T-Cutter to cut a bearing groove. I am trying to use the groove milling operation in mill planar but it does not allow it because it is not linear. Thank you for the help. Capture.PNG
3 REPLIES 3
Re: Maching Bearing Groove With T-Cutter
Planar profile will work, but the height settings are a little counter-intuitive. Haven’t got NX here at home, but one of the hole milling ops might work too!
Radial Groove Milling; if you don't mind cutting a little air...radial_groove.JPG
planar.JPGPlanar profile
