Machinig Knowledge editor MKE
Bonjour,
Howw gérer la liste de machine dans MKE. Je ai créer un environnment, mais je ne montre pas mes machines.
Avez-vous une idée?
Merci.
Emmanuel.
Re: Machinig Knowledge editor MKE
Esteemed Contributor
I don't know any French, but I guess I can tell from the image what you need to know.
The machines are read from the current configuration, so you need to have the entire CAM environment of your customer to get their machines.
Community Manager
Just a quick note to all of our forum readers and contributors:
Emmanuel's question in French is a perfect opportunity to point out to everyone that there is a "Select Language" pull-down at the top of the forum to invoke Google Translate.  It is machine translation, so it won't be perfect, but it is good enough to be helpful in most cases.
So we can read Emmanuel's question and he can read responses that we provide in English.
You might have overseas colleagues who could benefit from reading the forums as well, so you may want to recommend the Google Translate option for them, too.
Derek Hart
... if we're not having fun, we're not doing it right!
Have a look to the attached file used to run MKE. Where we define all the variables for the customer data.
Usig this .bat file unfortunatly the customer data isn't available. Do you know why?
Thanks.
Have you selected Open with Update to open the XML file?
This will update the information to match the configuration.
@DerekHart, Google translation is bad, it is much better to have the members post in English, if they are able to do so.
I have always had the experience, that broken English is much better than machine translation.
Yes.
Hi Stephan,
I thank you. I have open a call with staff SIEMENS. I give you the feed-back if I have a answer.
Emmanuel.
Hello
I have forgotten to declare the line below in the bat file:
set UGII_CAM_LIBRARY_MACHINE_DIR=%JANUS_CAM_CUSTOM_DIR%\library\machine\
set UGII_CAM_LIBRARY_MACHINE_ASCII_DIR=%JANUS_CAM_CUSTOM_DIR%\library\machine\ascii\
