Machining Feature Navigator
Hello.
Eng. model changed....& now I have 100s of features with x next to them.
How to update-reconnect Machining Feature Navigator Features to the new part geometry?
Kal.
NX 9.0.3.4 MP12 | PB 9.0.3.2 | NX11.0.2.7 MP12 | VERICUT 7.3.4
Re: Machining Feature Navigator
The ones marked with the black X are marked for deletion, since they are no longer valid at all.
This happens, when the through hole changes into a blind hole or when the number of steps changes.
There is no way to reconnect them at all, since that would have been done by the software already if possible.
Also don't forget to approve those marked as changed to apply the changes to the features.
Thank you Stefan.
Can you elaborate more on this statement..?
Kal.
The machining features at the top of your posted image are marked as changed, so you need to approve the changes through the context menu to have the features get updated correctly.
Stefan. Thank you! Smiley Happy
Just incase someone else runs into the same situation, please ref. image below...
Kal.
