Machining five axis
Best regards
I am mechanizing a project in a 5 axis, double rotary machine, please help with a code editor for five axes to visualize the machining trajectories. since I have problems in machining. I need to know the direction of rotation of the rods, if possible help with the post processor for 5 metric axes for the machine shown.
thank you
Re: Machining five axis
the post should be easy using post configurator. It's a simple machine kinematic. If you build the 3d machine and make a machine tool model with kenematics then you will be able to make a post based on one of the template machine types. Probably will be close to FANUC g-code.
