Machining gear
Hello I would like to machining gear according to image, in 4 axis.
Best regards
Re: Machining gear
Hi Richard
Do you want to mill like this? or something a bit different?
https://www.sandvik.coromant.com/de-de/products/coromill-162
Paul
Re: Machining gear
Hello Paul this same as in the video, I need to do this kind of machining, to show a client.
Thank you.
Richard.
Re: Machining gear
Hi Richard
I understand. If somebody doesn’t beat me too it I’ll try and build a sample for you.
Paul
Re: Machining gear
Ok Paul.Thank you.
 Regards.
Richard
Re: Machining gear
Gear manufacturing is a very tough manufacturing for me. I tried some operations. But I did not get a good result.
I only suggest you,5 axis streamline and tool axis 4 axis normal to part with rotation angle and projection method is normal to drive.Tool position is tanto. Also you could use generic motion tool path if you can.
I did not give you model, because result is not good.I did not love tool paths.But looks similar video.
Re: Machining gear
Thank you drafter 006, for the help.
Richard
Re: Machining gear
Hi Richard
Here is a sample to get thing moving. Sorry for the delay I've been traveling.
Let me know if you need some other style of cut.
Paul
Re: Machining gear
Thanks a lot for the help.Paul Hastrick.
Regards..
Richard
Re: Machining gear
Hot solution Mr. Hartrick :-)
Lead Product Manager - Mold & Die
