Machining knowledge bitmap error
Please some help, what to copy, or do i have to set some variables....
Re: Machining knowledge bitmap error
Esteemed Contributor
Seems you NX installation is corrupted or the UGII_... variable is pointing to the wrong location.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
The system cannot find the image for the pop up tooltip for an operation.
It does not affect the functionality.
I do not think the bitmap name is correct. What release is this?
What are you using the machining_knowledge template type for?
Mark Rief
Retired Siemens
NX 10, And i found the solution i was looking for
Thanks.
