Machining knowledge editor
I want to manage in MKE the parameter stepover on "passe" .
is it possible to manage this parametre in machining knowledge editor?
Do you have any idea?
thank you.
Re: Machining knowledge editor
Starting with NX 8.0.3 it is recomended to manage the operation parameters on the add-ons tab and not on the conditions tab.
In addition all operation parameters are available as an add-on.
Step over and such are usually separate add-ons, than the regular operation parameter add-ons, since the step over settings are shared between operation types.
Hi Stefan,
Your answer to responded well to my question.
a supplementary question:
What serve the parameters "comment and name" for step over.
thanks.
Emmanuel.
Those are just global ones that are applied to all NX objects.
You can check this on the customization tab under NX objects.
I don't see off the functionality that you indicate.
can you send me the way of this function in NX.
See image below.
ok I understood.
Thanks for this informations, I close the call.
