Do you mean
Reply
Solved! Go to solution
Making a post read only..
I was wondering if anybody knew of a way to make the file a postprocessor generates read only without having to manually find the file and toggle it.  Is there something in the tcl I can do?
Solution
Solution
Accepted by topic author JarvisIntern
‎08-26-2015 04:32 AM
Re: Making a post read only..
At the end of your post, close the output file:
MOM_close_output_file   $ptp_file_name
Then use the tcl file attributes command to change the protection.
Mark Rief
Retired Siemens
