Management of cutting tool's link with NC code
How do you manage cutting tool-NC code, part operations links? Do you use any software/system to manage this?
To explain it further, please see below.
Each CNC machine has many tools in its tool magazine. Each tool is used in multiple NC codes, for many parts and operations. If someone wants to replace one particular tool, that person should be able to get information on all NC codes, parts, operations where its been used.
Any idea?
Re: Management of cutting tool's link with NC code
Use MRL and a solid tool assembly and the tool assemblies will be components of the CAM parts.
Using the impact analysis, you get all the CAM parts where a particular tool is used.
I believe Teamcenter Manufacturing can also get this kind of report (from the "manufacturing BOM"?)
But the MRL is probably a better decision unless you are already planning on using TC Mfg... (note they are not mutually exclusive - you can use both)
In Teamcenter Manufacturing, the tools are resources, and you can check what CAM setups use them.
Mark Rief
Retired Siemens
Teamcenter Manufacturing is not needed, we only use MRL and I can get the relation between all MENCTool and MENCMachining revisions through the impact analysis.
If you use the ASCII library, you will get a separate virtual tool for each CAM part, so it will not be possible to track the tool usage.
With the regular assembly features and MRL you have the poor mans Tc manufacturing options, which should be sufficient.
I am aware and know about MRL, TC Manufacturing and looking other options.
About the only other option (that I know of) is "do your own".
Do something when posting (or possibly shop docs) that populates a database with program & tools used by that program.  I would also suggest storing cutting time as well (so if someone comes out with "super duper endmill #23" that cuts 10 times faster, you can update the program that uses the original mill for 3 hours before you do the program that uses the original mill for 15 seconds)
