Manufacturing details showing in drawing
I've been using NX for about 6 months after 15 years of Pro/Engineering and having some growing pains.  We are a small shop and I have been asked to start using the manufacturing module to post process for CNC milling.
So now that I opened manufacturing and created a program for a part, the drawing now has the manufacturing details imbedded into it and the details of the actual part are hidden.
How do I turn off or hide the manufacturing details in the drawing?
Thanks!
Re: Manufacturing details showing in drawing
Do not create a CAM setup inside of a design part.
NX does not force the part file separation like Pro/E does, but you are encouraged to do so anyways.
Make sure that your design part is a component of a separate drawing part and that it is also a component of a separate CAM setup part.
Enforce the master-model concept and build assemblies wherever possible, which makes reusing parts much easier.
Like @Stefan_Pendl says, use master model. Looking at your CAD part, did you go to File New, Manufacturing, Reference Existing Part, and choose a setup?
What do you mean by "manufacturing details"? Generally, nothing should be visible unless you are in the editing something in the Manufacturing application.
Also, as a general tip for new users, go to Menu, Help, Manufacturing Tutorials, and at least go through the first 2-3 tutorials.
Mark Rief
Retired Siemens
Thank you, I changed my approach to start using the master model theory.
I appreciate the help.
ERN
