Manufacturing error
Hi Guys,
I'm facing a problem on this, when i tried to use manufacturing features, it will come out with error which is (Invalid Configuration Error). Please help me
Thanks in Advance
7 REPLIES 7
Re: Manufacturing error
Can you give some more information about what you are trying to do?
Some pictures or a section of your log file showing the error?
This would help point you in the right direction.
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
Vericut 7.3,7.4.1,8.0.2
I would look in the syslog (menu -> help -> log file, or similar depending on NX version - you don't say what version you are using)
Look for the error message
then search up from there
I'm guessing there is one or more lines missing from a CAM configuration file, or pointing to something that doesn't exist.
Are you trying to use a CAM config file from an old version?
I'm using NX10, when i click manufacturing, it will come out with an error which is invalid configuration file
UGII_CAM_BASE_DIR D:\Siemens\Program\mach\
UGII_CAM_CUSTOM_DIR D:\Siemens\Program\mach\custom\
UGII_CAM_RESOURCE_DIR D:\Siemens\Program\mach\resource\
UGII_CAM_SAMPLES_DIR D:\Siemens\Program\mach\samples\
UGII_CAM_AUXILIARY_DIR D:\Siemens\Program\mach\auxiliary\
UGII_APT_VOC D:\Siemens\Program\mach\auxiliary\apt.voc
UGII_BCL_VOC D:\Siemens\Program\mach\auxiliary\bcl.voc
UGII_ISO_VOC D:\Siemens\Program\mach\auxiliary\iso.voc
UGII_UNIMAJ_VOC D:\Siemens\Program\mach\auxiliary\unimaj.voc
UGII_UNIMIN_VOC D:\Siemens\Program\mach\auxiliary\unimin.voc
UGII_VERICUT D:\Siemens\Program\win_nt\commands\vericut.bat
UGII_CAM_THREAD_MILL_DIR D:\Siemens\Program\mach\auxiliary\thread_mill\
UGII_CAM_THREAD_MILL D:\Siemens\Program\mach\auxiliary\thread_mill\thrm.dll
UGII_CAM_BATCH_DIR D:\Siemens\Program\mach\auxiliary\batch\
UGII_CAMBATCH_BACKGROUND_EXE D:\Siemens\Program\mach\auxiliary\batch\cambatch_background.exe
UGII_CAM_TAGGING_DIR D:\Siemens\Program\mach\auxiliary\tagging\
UGII_CAM_TAGGING_DLL_DIR D:\Siemens\Program\mach\auxiliary\tagging\application\
UGII_CAM_TAGGING_ENGLISH_DIR D:\Siemens\Program\mach\auxiliary\tagging\english\
UGII_CAM_TAGGING_METRIC_DIR D:\Siemens\Program\mach\auxiliary\tagging\metric\
UGII_CAM_FILE_SEARCH_PATH .\;D:\Siemens\Program\mach\;D:\Siemens\Program\mach\resource\
UGII_CAM_CONFIG_DIR D:\Siemens\Program\mach\resource\configuration\
UGII_CAM_CONFIG D:\Siemens\Program\mach\resource\configuration\cam_general.dat
UGII_SHOPS_DIE_MOLD_CONFIG D:\Siemens\Program\mach\resource\configuration\shops_diemold.dat
UGII_SHOPS_MACHINERY_CONFIG D:\Siemens\Program\mach\resource\configuration\shops_machinery.dat
UGII_CAM_TEMPLATE_SET_DIR D:\Siemens\Program\mach\resource\template_set\
UGII_CAM_TEMPLATE_PART_DIR D:\Siemens\Program\mach\resource\template_part\
UGII_CAM_TEMPLATE_PART_ENGLISH_DIR D:\Siemens\Program\mach\resource\template_part\english\
UGII_CAM_TEMPLATE_PART_METRIC_DIR D:\Siemens\Program\mach\resource\template_part\metric\
UGII_CAM_TEMPLATE_IMAGE_DIR D:\Siemens\Program\mach\resource\template_part\images\
UGII_CAM_LIBRARY_TEMPLATE_DIR D:\Siemens\Program\mach\resource\template_dir\
UGII_CAM_LIBRARY_TEMPLATE_DATA_DIR D:\Siemens\Program\mach\resource\template_dir\
UGII_CAM_SHOP_DOC_DIR D:\Siemens\Program\mach\resource\shop_doc\
UGII_CAM_PART_DOC_CONFIG_FILE D:\Siemens\Program\mach\resource\shop_doc\shop_doc.dat
UGII_CAM_WORK_INSTRUCTION_DIR D:\Siemens\Program\mach\resource\owi\
UGII_CAM_POST_DIR D:\Siemens\Program\mach\resource\postprocessor\
UGII_CAM_POST_CONFIG_FILE D:\Siemens\Program\mach\resource\postprocessor\template_post.dat
UGII_CAM_LIBRARY_MACHINE_CONFIG_DIR D:\Siemens\Program\mach\resource\postprocessor\
UGII_CAM_USER_DEF_EVENT_DIR D:\Siemens\Program\mach\resource\user_def_event\
UGII_CAM_TOOL_PATH_DIR D:\Siemens\Program\mach\resource\tool_path\
UGII_CAM_WIZARD_DIR D:\Siemens\Program\mach\resource\wizard\
UGII_CAM_DEBUG_DIR D:\Siemens\Program\mach\resource\debug\
UGII_CAM_DEFAULT_TYPE_TEMPLATE D:\Siemens\Program\mach\resource\template_set\cam_general.opt
UGII_CAM_IMAN_TYPE_TEMPLATE D:\Siemens\Program\mach\resource\template_set\cam_teamcenter_general.opt
UGII_CAM_FEATURE_DATA_DIR D:\Siemens\Program\mach\resource\feature\
UGII_CAM_FEATURE_DATA_ENGLISH_DIR D:\Siemens\Program\mach\resource\feature\english\
UGII_CAM_FEATURE_DATA_METRIC_DIR D:\Siemens\Program\mach\resource\feature\metric\
UGII_CAM_FEATURE_IMAGES_DIR D:\Siemens\Program\mach\resource\feature\images\
UGII_CAM_SPREADSHEET_DIR D:\Siemens\Program\mach\resource\spreadsheet\
UGII_CAM_MACHINING_KNOWLEDGE_DIR D:\Siemens\Program\mach\resource\machining_knowledge\
UGII_UG_LIBRARY_DIR D:\Siemens\Program\mach\resource\ug_library\
UGII_CAM_LIBRARY_DIR D:\Siemens\Program\mach\resource\library\
UGII_CAM_LIBRARY_TOOL_DIR D:\Siemens\Program\mach\resource\library\tool\
UGII_CAM_LIBRARY_TOOL_ASCII_DIR D:\Siemens\Program\mach\resource\library\tool\ascii\
UGII_CAM_LIBRARY_TOOL_GENIUS_DIR D:\Siemens\Program\mach\resource\library\tool\genius\
UGII_CAM_LIBRARY_TOOL_INCLASS_DIR D:\Siemens\Program\mach\resource\library\tool\inclass\
UGII_CAM_LIBRARY_TOOL_ENGLISH_DIR D:\Siemens\Program\mach\resource\library\tool\english\
UGII_CAM_LIBRARY_TOOL_METRIC_DIR D:\Siemens\Program\mach\resource\library\tool\metric\
UGII_CAM_LIBRARY_TOOL_GRAPHICS_PATH D:\Siemens\Program\mach\resource\library\tool\graphics\
UGII_CAM_LIBRARY_TOOL_ASCII_LOAD_LIMIT 100000
UGII_CAM_LIBRARY_DEVICE_DIR D:\Siemens\Program\mach\resource\library\device\
UGII_CAM_LIBRARY_DEVICE_DATA_DIR D:\Siemens\Program\mach\resource\library\device\ascii\
UGII_CAM_LIBRARY_DEVICE_ASCII_DIR D:\Siemens\Program\mach\resource\library\device\ascii\
UGII_CAM_LIBRARY_DEVICE_INCLASS_DIR D:\Siemens\Program\mach\resource\library\device\inclass\
UGII_CAM_LIBRARY_DEVICE_GRAPHICS_PATH D:\Siemens\Program\mach\resource\library\device\graphics\
UGII_CAM_LIBRARY_MACHINE_DIR D:\Siemens\Program\mach\resource\library\machine\
UGII_CAM_LIBRARY_MACHINE_ASCII_DIR D:\Siemens\Program\mach\resource\library\machine\ascii\
UGII_CAM_LIBRARY_MACHINE_DATA_DIR D:\Siemens\Program\mach\resource\library\machine\ascii\
UGII_CAM_LIBRARY_MACHINE_GENIUS_DIR D:\Siemens\Program\mach\resource\library\machine\genius\
UGII_CAM_LIBRARY_MACHINE_INCLASS_DIR D:\Siemens\Program\mach\resource\library\machine\inclass\
UGII_CAM_LIBRARY_MACHINE_GRAPHICS_PATH D:\Siemens\Program\mach\resource\library\machine\graphics\
UGII_CAM_LIBRARY_INSTALLED_MACHINES_DIR D:\Siemens\Program\mach\resource\library\machine\installed_machines\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_DIR D:\Siemens\Program\mach\resource\library\feeds_speeds\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_ASCII_DIR D:\Siemens\Program\mach\resource\library\feeds_speeds\ascii\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_DATA_DIR D:\Siemens\Program\mach\resource\library\feeds_speeds\ascii\
UGII_CAM_LIBRARY_FEEDS_SPEEDS_GENIUS_DIR D:\Siemens\Program\mach\resource\library\feeds_speeds\genius\
UGII_CAM_LIBRARY_UDF_DIR D:\Siemens\Program\mach\resource\library\udf\
UGII_UG_LIBRARY_GENIUS_TCP_HOST localhost
UGII_UG_LIBRARY_GENIUS_TCP_PORT 2326
NX Ship Names Recipes File does not exist.
Check-mate: the configuration file 'D:\Siemens\Program\design_tools\checkmate\customization\ugcheckmate.dat' does not exist.
KF search path used is from the registry, not from UGII_KF_USER_CLASS_DIR
UGCHECKMATE directory 'D:\Siemens\Program\design_tools\checkmate' does not exist.
Successfully loaded dynamic module D:\Siemens\Program\UGII\libnxvtk.dll
Command line: D:\Siemens\Program\UGII\ugraf.exe -nx
A master env file has not been loaded
Is this an OOTB set up or have you got customised set up files?
Is the last post you made the last bit of your log file after you get the error come up?
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
Hi Guys just solve the problem, its because im moving the file from c to d.the best way to solve it i reinstall back on c.Thanks everyone really appreciate it
