Manufacturing sequence Z Level operation
Good afternoon, colleagues!
I have a problem with the Z Level operation. I need to manufacturing the pockets in the following sequence (see Z_Level_01.jpg). But as a result of generating the path, NX CAM turns out like this (see Z_Level_02.jpg). How do I perform the manufacturing of pockets (bosses) in the needed sequence?
3 REPLIES 3
Re: Manufacturing sequence Z Level operation
In area milling you should be able to use the Cut Region manager to order the regions. You should be able to set the area milling steep cut pattern to zlevel and get what you are getting with the zlevel operation.
Mark Rief
Retired Siemens
Ok. Thank you.
I try to use Cut Area "management", but - no results. For your sample (may be real part more complex, of course) will be more useful set one pocket as Cut Area and make instances as you want, in any sequence.
