Manufacuring resource library with mach-3 license.
Can I use the manufacturing resource library in a non-Teamcenter environment with a nx mach-3 license or do I need to buy another license?
NX 12.0.2
Re: Manufacuring resource library with mach-3 license.
You need to have the server portion of Teamcenter installed and running to be able to set up MRL.
For native NX you need the MRL connect license in addition to use MRL.
Starting with Teamcenter 10.1, may be 9.1, you also need a classification access license for each user connecting to the MRL.
To access MRL from native NX, you will probably need "Manufacturing Resource Library Connect for NX", but talk to your Siemens accout rep or partner to be sure. They can check exactly what is in your current license bundles and determine what, if anything, is needed.
Mark Rief
Retired Siemens
We do use MRL from native NX and you definitely need the MRL connect for NX license, there is no way arround it.
In addition we have found out the hard way that the classification access license is mandatory for each MRL user, since MRL connect started being unreliable after migrating from Teamcenter 8.3 to 10.1 Smiley Frustrated
