Menu Script CAM Question
PLM World Member Builder PLM World Member Builder
Hello All,
I'm trying to call an NX Open .dll after the Postprocessing button has been pressed from within CAM but I'm having a few problem that I'm hoping that someone can assist with.
Following the documentation I've created two files and placed them in a "startup" directory, but within NX I'm getting the following errors
In NX9
MB_LOADED_MENU_FILE Loaded startup menu file: D:\NX_Data\NXOPEN\DNC_Transfer\startup\cam.men
MB_MENU_FILE_LOAD_FAILED Startup menu file load failed for: D:\NX_Data\NXOPEN\DNC_Transfer\startup\DNCMenu.men
   Cannot edit menu bar! Menu bar has not been created.
In NX75
MB_LOADED_MENU_FILE Loaded startup menu file: I:\NX_Data\NX75custom\NXOPEN\DNC_Transfer\startup\cam.men
MB_LOADED_MENU_FILE Loaded startup menu file: I:\NX_Data\NX75custom\NXOPEN\DNC_Transfer\startup\sample.men
Syntax_Error Syntax error at line 4 in file: I:\NX_Data\NX75custom\NXOPEN\DNC_Transfer\startup\DNCMenu.men
   Cannot MODIFY button UG_CAM_ONT_OUT_MACHINE_DATA. The button does not exist.
MB_LOADED_MENU_FILE Loaded startup menu file: I:\NX_Data\NX75custom\NXOPEN\DNC_Transfer\startup\DNCMenu.men
cam.men
VERSION 130
EDIT UG_GATEWAY_MAIN_MENUBAR
MODIFY
APPLICATION_BUTTON UG_APP_MANUFACTURING
MENU_FILES DNCMenu.men
END_OF_MODIFY
DNCMenu.men
VERSION 121
MODIFY
BUTTON UG_CAM_ONT_OUT_MACHINE_DATA
LABEL Postprocess & Transfer to DNC
ACTIONS/POST DNC_Transfer.dll
END_OF_MODIFY
Any Ideas?#
Jason
4 REPLIES 4
Re: Menu Script CAM Question
What I'm guessing....
The CAM menu stuff doesn't exist when NX starts.
So you have to do these menu edits as (or after) CAM is started.
What I did for drafting (to replace all the dialogs to fill in the titleblock)
Put this .men in the \startup\ folder
VERSION 120
MODIFY
  APPLICATION_BUTTON UG_APP_DRAFTING
  MENU_FILES GTAC_Populate_Title_Block.men
END_OF_MODIFY
Then put this .men in the \application\ folder
VERSION 120
MODIFY
  ! This button is for populate title block command launched from Drawing Format toolbar
  BUTTON UG_DRAFT_DRAWING_FORMAT_TITLE_BLOCK_POPULATE
  ACTIONS/REPLACE GTAC_Populate_Title_Block.dll
  ! This button is for populate title block command when a MB3 > Populate on title block is invoked
  BUTTON UI_TITLE_BLOCK_EDIT_TITLE_BLOCK
  ! This button is for populate title block command when a new drawing is created
  BUTTON UI_DRAFT_EDIT_TITLE_BLOCK_FOR_DRAWING
  ! This button is for populate title block command when a new sheet is inserted
  BUTTON UI_DRAFT_EDIT_TITLE_BLOCK_FOR_SHEET
END_OF_MODIFY
I *believe* if you do a similar setup for CAM, you should be able to modify the "postprocess" button.
Thanks for the suggestion Ken, I moved the DNCMenu.men file to the application folder but that still didn't work. The error message appeared further on in the log file
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\NX\90\ugii\menus\ug_cam.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\NX\90\ugii\menus\ug_synchronous.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\NX\90\mach\auxiliary\batch\application\ug_cam_batch.men
MB_MENU_FILE_LOAD_FAILED Error loading menu file: DNCMenu.men
Maybe this can't be achieve within CAM?
Many Thanks
Jason
DNCMenu.men needs to be in the application folder.
BUT
Did you add a SEPARATE .men file in the \startup\ folder?
with the UG_APP_MANUFACTURING (or whatever it is)?
Maybe you did (it kind of looks like it), but you didn't say.
Maybe the button names are different than you think?
I'd comment everything that changes behavior out in DNCMenu.men, make sure the .men loads that way.
Then uncomment one button at a time, see if OK or error.
You might want to contact GTAC about this.
Thank Ken, I've now solved it with your help. After following your instructions that at first didn't appear to work, I've found there was a typo in the menu I was editing
should have been
Your a Star!
