Merge small faces
Hi
I'm working with a solid and I would like to clean up the geometry. So, in a certain area there are small faces.
I would like to fuse them or merge them but I don't know how can I do it.
Find attached the figure
Re: Merge small faces
Hello, as far as I know, those faces can't be merged. Why do you need to merge them?
On the other hand, this is a manufacturing forum, try to ask in the Siemens Desing forum: http://community.plm.automation.siemens.com/t5/NX-Design-Forum/ct-p/NXforDesign news://dnews.industrysoftware.automation.siemens.com.
Frank.
P.S. Edited to change the url of design  forum.
Thank you very much. I'm going to post it there.
