Mill multi blade
Good afternoon,
I have tried to program this part with mill multi blade (MULTI_BLADE_ROUGH) but it looks that I´m too stupid for that.
Is it possible with mill multi blade or can somebody suggest another operation???
Thanks!
Martin
Re: Mill multi blade
Hi Martin,
Attached you can find my version.
This is how I would try to make this part.
I did not spend any time optimizing this, I dont know what machine you have or the setup you're gonna use.
Sven
NX11.0.1
Thank you Sven!
I think your solution works fine for me.
