Missing "Use Arc Axis" in new Drilling-Module in NX10
Hello!
In the PTP-Drilling-Template I have the possibility to specify "Use Arc Axis". With this function I have the possibility to have an output like this in PP:
N10510 MCALL CYCLE_L89(147.,145.,2.,64.82,600.,17.,0,0,306,2546.)
N10520 X0.0 Y362. B=DC(-67.5)
N10530 Y388. B=DC(-90.)
N10540 Y414. B=DC(-112.5)
N10550 Y440. B=DC(-135.)
N10560 MCALL
This is the output for holes on a circumferential surface.
In the new Holemaking-DRILLING-Module in NX10 I miss this function. Is there a reason for it?
Thanks for help
Werner
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
17 REPLIES 17
Re: Missing "Use Arc Axis" in new Drilling-Module in NX10
The new operation types for drilling don't need this to be enabled explicitly, it is always enabled.
The axis should come from the cylinder of the hole you selected.
Hello!
I've experimented again and I found out that the variable mom_tool_axis_as_arc_axis is set to 1 in PTP with "Use Arc Axis". This is missing in Holemaking. Our PP works with this variable.
Do we get a solution for this missing variable or do I have to create a UDE-Variable to handle this?
Thanks for help.
Werner
Werner
Have you tried to check the operation type?
global mom_operation_type
if { [string match "Drilling" $mom_operation_type] } {
    # your code goes here
What do you want to achieve if you know the operation-type? Of course in the post there is a query:
if {([string match "Point to Point" $mom_operation_type] || [string match "Hole Making" $mom_operation_type] || [string match "Drilling" $mom_operation_type]) } {
                  if { [info exists mom_tool_axis_as_arc_axis] && $mom_tool_axis_as_arc_axis == 1} {
Werner
Hallo Werner,
Can you please share a simple test part to illustrate the situation that you are struggling with?
Tom van 't Erve
NX CAM Development
Drilling does not offer this, since it is always active.
    set mom_tool_axis_as_arc_axis 1
Hello!
Stefan, this is not what we want. In some cases we don't want to have this output. The user should be able to change the output. In past (with PTP) he was able to say "Use Arc Axis" or not.
Tom, in the Attachement you find some examples. Please see the debug-files. In the debug-files from PTP you find the mom_tool_axis_as_arc_axis, which is set to 1 by programming "Use Arc Axis".
Thanks for help to all.
Werner
Werner
"Use arc axis" was never meant to indicate a cylindrical drill pattern, it was only used to indicate that the axis of the arcs should be used instead of a single common axis.
To limit the output to YZC, the LOCK_AXIS UDE is usually used.
