Mits EDM 4axis 8.5 help
Trying to create a new EDM post, I pick the Mits from the library and the UV output does not even seem to be close.  What do I have to do to get my UV output as incremental?
Re: Mits EDM 4axis 8.5 help
To make your post incremental just add this to the beginning
MOM_incremental ON fourth_axis fifth_axis
However, I find most people just set the switch on the machine to Absolute U/V.
Should be in your maintenance>switch screen on the machine. Toggle on=absolute
An issue I found posting in incremental is that UV values are truncated. At the end of the toolpath you may not end up at a clean U0 V0.
