Modeler Error when trying to import .prt or add .prt to assembly
Anyone else seeing this problem?
Error
Dennis Rathi
Creations Unlimited
Re: Modeler Error when trying to import .prt or add .prt to assembly
There will be more hints in the syslog for which kind of object the system is failing.
Have you already tried the following procedure?
  1. open a fresh NX session
  2. open the failing part
  3. run part cleanup in gateway
  4. save the part
  5. close the NX session
It is very important to run part cleanup only in gateway and in a fresh NX session, so there is nothing left over that prevents the cleanup.
