cancel
Modeling points and lines do not show in drafting views
We just upgraded to NX 8.5.2.3. Using an existing drawing and creating a new view, modeling points and lines will not display in view. This is something we do all the time to show datum's and call out x,y,z points on drawings. So it is not something new to us.
If we create a projected view from an existing view that DOES show them, the new view WILL show them also. If we create a new projected view from an existing view that does NOT show them, the new view will NOT show them either. We have tried almost every option in view style and layer settings and Yes we have used "reset to global" with no success.
Has anyone else had this problem and solved it?
Thanks for your help.
