Modified robot won't move
I have modified an existing robot (KUKA_KR180_R2500_extra) by adding a device to the robot with another axis (so I got a 7-axis robot instead of a 6-axis robot) I can use the motion preview and move all axis manually in the correct way. When I try to simulate a tool path or anything, however, the robot doesn't move at all.
I tried to edit the Robotics.cdl and added the 7th axis where I thought it makes sense.
A picture of the kinematic chain and the Robotics.cdl  (as txt) are attached, I hope you can find some answers.
Cheers,
Tobi
Edit: I use NX 11
Re: Modified robot won't move
what is warning show?
There's no error message at all. When I open up the robot itself, it has an ! behind its name in the window name. I can get rid of it by refreshing everything, but when I save it and re-open it, the ! appears again...
would you mind shared the Device date for us?,maybe we can find what is going on for you.
