MoldWizard & NX10, problems
I have problem in Moldwizard sub insert and slider lifter library. whenever i am going to add parts then all library seen empty. from where i should download this libraries.
please help me i have NX 9.0
Re: MoldWizard & NX10, problems
You need a separate library installation. You can get the library install from our software download site, under Product Updates/Moldwizard ... these install are NX version based.
https://download.industrysoftware.automation.siemens.com/
Thank you. But it is asking for Authentication and pasword.
You need to use your webkey details ... or ask your Siemens Partner to download it for you.
