Move opertion in sync manager
Hello everyone,
Do you know how to move operation in sync manager?
Re: Move opertion in sync manager
it is not an answer, but why don't you move them in Operation Navigator?
Do you think it is a good idea to have operations in different order in ONT and in Sync Manager?
- just my curiosity...
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
I just want to adjust operation line in the sync manager. Except changing the order in the program group.
I don't think it is doable with Sync Manager to change order of operations within one channel. As I mentioned, I don't see a reason why it would be needed in such simple case.
I use Sync Events to organize operations in time between channels, but I never reordered operations in single channel as you showed it on picture
How I can move "grove od" to left side" contour profile" for synchronization.?
Typically, which channel an operation is on is governed by which Carrier object it is under in the "Machine tool view" of the operation navigator.
So move the operation's tool parent to be a child of the proper carrier.
