Multi Blade Finish
Hi All,
In the multi blade finish module for blade finish drive method I'm using helical cut pattern but see no way to change or control the scallop size or step down on blade. Am i missing something here?
Re: Multi Blade Finish
Did you check by clicking on the symbol on top left corner for more dialogue options?
BR,
BR
Mak
TC10/NX 9
Hi Mak_Jo
Thanks for the reply
I have found the solution. The cut steps are in Cut Levels and not in Blade
finish. My 1st time with the new multi blade module
Thanks again,
Rick D
Information transmitted by this email is proprietary to LAI International and is intended for use only by the individual or entity to which it is addressed, and may contain information that is private, privileged, confidential or exempt from disclosure under applicable law. If you are not the intended recipient or it appears that this mail has been forwarded to you without proper authority, you are notified that any use or dissemination of this information in any manner is strictly prohibited. In such cases, please delete this mail from your records.
Rick, if it's your first time, be sure to go through the Turbomachinery Milling tutorial. It opens a sample part and walks you through all the operations. It's included in every CAM installation under Help, Manufacturing Tutorials. This is one of the steps:
Mark Rief
Retired Siemens
