Multi Tooth Threading Tool
It's  been about 20 years since I did this and not in NX but what is the best way to describe a multi tooth threading insert fot turning and where would you consider the zero point of the tool
Mike
NX 11.0.2.7
Win 10
Re: Multi Tooth Threading Tool
You might want to try using an od groove tool with a taper on leading edge and a tracking point on front. Since NX does not graphicly display the actual thread shape in replay, this should work. An added bonus, a tool holder...
