Multi-line message in Assert CSE-Command
Hello!
Is it possible?
I try to use \n, \\n and some escape-symbols - no results.
4 REPLIES 4
Re: Multi-line message in Assert CSE-Command
I'm not expecting these to work, but...
did you try "\r"?
"\r\n"?
Not working,,
With NX8.5 control signs like new line (\n) should be supported.
It depends where the output will be either Message box or Details window.
With which version do you check?
Thomas
Thomas Schulz
Siemens PLM
Thomas, thank you for answer!
I think - you right, I will check it few days later, just now in Russia "great holidays"..
I try to do it in NX7.5, for one my customer, but no in latest NX version.
