NO arc output after multi_axis tool_path output
Hi guys:
I ran into a problem when I created a postprocess in PB.when I post  all the operations together  ,if there is a multi_axis tool_path in it , after this multi_axis tool path ,it cannot output the path with ARC , it is all linear interpolation. I know there's some parameter that controls it, that's not initialized, but I can't find it.Who can help me???01.JPG02.JPG
4 REPLIES 4
Re: NO arc output after multi_axis tool_path output
Mario:
Normally, the kinematics should have been reset at the end of the 5-axis operation, so I don't know why this isn't the case in your post; however, the parameter you're after is:  mom_kin_arc_output_mode
You set it as follows:
set mom_kin_arc_output_mode QUADRANT    or    set mom_kin_arc_output_mode FULL_CIRCLE  - depending on how you want to output your arcs.
Follow this with MOM_reload_kinematics to update everything.
~Ulas
set mom_arc_mode CIRCULAR / set mom_arc_mode LINEAR
MOM_reload_variable mom_arc_mode
Thanks for your help ~~~
It 's really working .but firstly  you should decare this variable in the "end of path "
I set it in the start of operation, I check the operation and set it.
