NULL or \0 or \x0 in tcl
Hello!
I have a problem with output NULL symbol in tcl, for example:
MOM_output_literal "\0"
or
MOM_output_literal "\x0"
I see in output file
АЂ %
N001M63
And - no problems with any anothers symbols...
Thanks.
Re: NULL or \0 or \x0 in tcl
Something to do with the MOM intrepreter for TCL checking for something (within the parentheses)? and performing substitution?
anyway, do this any your output will be what you expect.
MOM_output_literal "\\0"
MOM_output_literal "\\x0"
Not worked. I insert \007 (Bond, James Bond) and later edit it to 00. Not so good solution..
2 \ not 1
2, of course, 2..
N35 \x0  - result
Or - you have another result?
From TCLers' WIKI"
Many languages have a special "null" value (be it null or NULL or nil or ...) that is different from all other values — sometimes it is not even equal to itself — and somehow represents "data missing". Tcl doesn't have this, among other reasons because it violates the everything is a string principle."
I read it.
How about the following?
MOM_output_literal "[format "%c" 0]"
N35 АЂ
A same result for MOM_output_literal "\0"
Then there seems to be no other solution than outputting a marker and replacing it after the post run with the null character.
MOM_output_literal "NULL_CHAR"
' use regular Tcl/Tk commands to replace the marker with \0 in end_of_program
