NURBS output
I am trying to modify my post for sinumerik 810d to output nurbs motion for fixed contour and zlevel operations in order to shorten long NC programs. I have already posted similar thread some time ago but still i couldnt make it work. Could anyone from this formu help me out and modify this post for me?
Re: NURBS output
Does NURBS output (or the Siemens specific nurbs output) require a license feature?
Re: NURBS output
There are two licenses available, both are included in the latest CAM bundles for 3 and more axis milling.
  • nurb_output_enabler
  • sinumerik_spline
You can also get them through the NX 3 Axis Milling Add-on ( NX30433 ).
Re: NURBS output
Nurbs output is included in my license package. If i use standard 5 axis sinumerik post, nurbs are generated. I cannot get to work nurbs with my customized 3 axis 810d post.
Re: NURBS output
Now you need to figure out where it is failing.
1) Make sure the internal toolpathhas nurb data.  You can list the toolpath, or, post with your other post.
2) Does your post have a handler for the nurbs data?
- (Assuming post builder) "Program & tool path" tab -> "Program" tab -> Tool Path/Motion (in list at left) -> Is there a block "NURBS Move"?
3) if that block exists, what is in it?
Re: NURBS output
So you are using post builder 10.0.3
Have you set up PB_CMD_init_nurbs correctly?
Re: NURBS output
I do not have NURB tab in motion tab.
I have attached a screenshot of PB CMD init nurbs setup.
I am using 10.0.3 PB
Re: NURBS output
Tcl is case sensitive, so you need to set the output mode as shown in the comments, you cannot alter the character case.
As it is now, nurbs output is disabled.
Re: NURBS output
I do not know how to add this tab to Motion. It was same with Helix move that I have imported custom command and helix tab did not show in Motion.
Could you please advise?
Re: NURBS output
The init helix is "self contained"
I'm thinking the "init nurbs" just sets some flags, there still needs to be an event handler.
Looking at a new Siemens 840D post (just created to see what is going on), I think you need a proc "MOM_nurbs_move"
So:
1) Correct the case sensitive portion of the init nurbs (as pointed out)
2) Add a proc "MOM_nurbs_move"
to do (2), assuming you are not "sourcing" in a tcl file, create a custom command like "PB_CMD_LBSMFG_Define_Nurbs_handler", add it to "start of program" event
Code (to start) will be
uplevel #0 {
   proc MOM_nurbs_move { } {
      MOM_output_text "Nurbs move output here"
  } ;# MOM_nurbs_move } ;# uplevel
Try that much - see if you get a bunch of lines in the posted code "Nurbs move output here"
If you get that far, now you'll have to do the work to get the proper block template defined & values for those words.
