NX 10.0.3 Extremely Slow Performance Opening Floor Wall
When I copy / plaste or create a new Floor Wall and use "Follow Part" it really bogs down anytime a change is made. If you use a Zig Zag pattern it is very fast.
Containment > Blank > is set to Thickness with .100 on the floor default.
"Initiliaizing the In Process Workpiece from the Geometry Group" shows at the bottom while this delay happens where I can not do anything else. Simple parts and simple cuts.
I'm using an i7-5930K CPU @ 3.50GHz and 24GB of ram so I dont think its the computer?
NX 10.0.3.5 MP9
Anyone have any ideas?
Dennis Rathi
Creations Unlimited
7 REPLIES 7
Re: NX 10.0.3 Extremely Slow Performance Opening Floor Wall
Timed this occurance
12 seconds from opening a Floor Wall Operation until it responds and lets me change a setting.
Dennis Rathi
Creations Unlimited
Seems related to the other drive methods now too.
Couple reboots
Upgrade to MP10
Upgraded my Quadro K4200 drivers
No change
Turn off preview and it is good.
I wonder.... could this be because my workpiece stock is "offset" = .010?
Dennis Rathi
Creations Unlimited
If your blank geometry in the workpiece group is an offset from the part geometry, this could be a real problem, since the part might be complex with many faces.
Generally it is good to disable the preview in the customer defaults for floor-wall operations, which disables the preview for each newly created floor-wall operation after the change of the customer default.
Hi Stefan
But what I dont understand is why the toolpath is looking at the IPW anyway when blank is set to thickness???
Should only look at the face which I selected
Dennis Rathi
Creations Unlimited
If there is any kind of blank specified it will be used.
If you can, you should report the problem to GTAC with the part submitted, so that performance can be improved in the future.
If you don't need the IPW aware floor wall operation use the regular one.
Ill try to log a file with GTAC next week. Racing the clock this week.
Dennis Rathi
Creations Unlimited
The product manager for this is traveling, but he suspects the preview. If you turn off preview, is the performance what you would expect? If you log a call with GTAC, he can take a look at your part when he returns.
Mark Rief
Retired Siemens
