NX 10.0 - movie capture from CAM (codec)
I have some question about movie capture. Many times I need to send or show to my customers an animations about machining their parts.
I know that there is some Trick to install the good codec and add proper environment variable.
So.. I tried first to install ffdshow_x64 codec pack and next step: environment variable as UGII_MOVIE_CODEC=FFDS
On first it was working only on my latest Nx versions 8.5 and 9.0 but on my NX10.0 still was only one Microsoft Video 1 codec (..arghhh). Dont know why but I remeber that I change internal windows setup to use only ffdshow and after comupter restart on every NX version I have only now Microsoft Video 1 (movie >> settings).
Reinstall of codec pack didnt work so I dont have any idea how to fix it Smiley Happy
Best regards
Engineering >> NX10.0 Performance in the making
Re: NX 10.0 - movie capture from CAM (codec)
I would contact GTAC with this issue, or post it in the Design Forum.
Mark Rief
Retired Siemens
Hey Mark,
Ok I will post it again in Design Forum.
Best regards
