NX 10 to 11 transfer
HI,
I was wondering if there was a good way to transfer my customer defaults from nx 10 to 11. Also, I have a lot of custom Templates and Operations and various other settings that I frequently use that I'd like to bring over as well. I was wondering if there was a way other than copy / pasting everything to the new nx11 folders that would be more reliable and efficient.
Thanks.
Re: NX 10 to 11 transfer
For customer defaults, I would export your changes only (go to the eyeball button), and then import those in to 11.
For templates, you should compare your templates to tehe new our of the box. If you just use your old templates, you will miss new functionality in NX11.
We are working on some tools to help with the template comparison, so if you are familiar with vb and template management, this will be able to help you. I'll try to get a movie posted in the next few weeks.
Mark Rief
Retired Siemens
