NX 11.0.2 IPW problem creation
after installing new version of NX (11.0.2), i came across the problem in computing IPW for my workpiece.
It shows that my IPW in workpiece is calculated and up to date, but in reality there is no IPW at all. Therefore i can not continue with my work.
I've sent this problem to Siemens already, but maybe some of you encountered this as well and have a solution for this.
Does anybody come across the same problem ? Any kind of solution or help would be apprecieted.
Thank you
Re: NX 11.0.2 IPW problem creation
If you are talking about ISV CSE machine tool simulation we introduced a way to initialize the blank based on the IPW from the previous operation. If you don't like that it can be switched of in the customer default.
Manufacturing->Simulation&Visualization->ISV Options->In Process Workpiece->Load IPW from Operation
Thomas Schulz
Siemens PLM
IPW not updated
help me!
cảm ơn
Select the WORKPIECE group => RMB => workpiece => parallel generate 3D. This should update the IPW for all operations.
THANK YOU!
I reinstalled VERSION 11:01
 AND everything is back to normal
Have you also reported the problem to GTAC so it gets fixed for the next releases?
