NX 11 problem with cut levels windows
a have problem wit cut levels in NX 11. In NX9 is everything ok. On picture NX9 is icon list and tab wih levels.
NX9NX9
In NX 11 this icon mistake
NX11NX11
I have NX 11.0.1.11 MP2and use NX11 for about 2 months. At the beginning this icon was where it supposed to be a then it has lost. I don´t know what happened.
Do you have any idea how to fix it?
Best Regards
Re: NX 11 problem with cut levels windows
Try 'Show Collapsed Groups' (under the gear icon).
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
Thank you for quick reply....:-))
