NX_12 - SUSPECT GEOMETRY
Hi !
A have a problem with groove milling on "mill_contour". I have a problem with my pocket milling, when I using "CAVITY_MILL" for roughing and "FIXED_CONTOUR" for finish milling. I'll get a message about SUSPECT GEOMETRY .
Can anyone advise me ??
Thanks Jacob...
Re: NX_12 - SUSPECT GEOMETRY
Maybe there is some problems with the geometry, you can check the geometry by command examine geometry, then try to heal geometry.
