NX 9 POST PROCESSOR SET TO DEFAULT
Hello everyone,
   I was trying to set a post processor of mine into the dialog box that appears while we select post process in the operation but i am unable to set to it i have it browse evrytime . Can anyone tell how to se it default??
4 REPLIES 4
Re: NX 9 POST PROCESSOR SET TO DEFAULT
Go to:
Menu --> Tools --> Install NC Postprocessor...
Or you can manually add it to:
(...)\MACH\resource\postprocessor\template_post.dat
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
Thanks @Marek_Pawlus I will try this
but I don't have .dat file I have .def .pui . .tcl files
.dat file is not part of postprocessor. It is kind of "list of postprocessors" which you can see in postprocess dialog in NX. I pasted the directory where you can find it.
If you don't know how to do it, I suggest to ask author of the postprocessor to install it for you.
Thanks @Marek_Pawlus Smiley Happy
