NX CAM B-axis Contour Turning Operation Cappability in NX11
Hello CAM Community,
I would like to request for the B-axis Contour Turning Operation in NX CAM similar to the cycle that exist in other CAM softwares. Refere to the Link for Video on how this operation would look like. Wish NX CAM team had developed this operation long time back.
https://youtu.be/2mIVwTkDwes
If this operation exist in NX11 version, kindly help to provide help documentation so that i explore further. If any of the community members figured out on how to create similar toolpath kindly share your experience here for the CAM community benefit.
Thank you all,
Best Regards.
5 REPLIES 5
Re: NX CAM B-axis Contour Turning Operation Cappability in NX11
There is a possibilty to work with variable B-Axis. It starts with NX11 and is only available if set an ENV-Variable.
There is a relative Mode
And an interpolation mode
I did not do anything with it and from my sight it is very limited and not very close to you video, but perhaps better than nothing. I do not know how it goes on with it in the future...
If it is interesting for you please sent me a PN because i do not know if it is allowed to post Preview ENV´s...
greetings,
Andre
It will be available in NX 12.01
Siemens Industry Software Pte. Ltd.
Hi Andre,
thank you for sharing. good to know. will test it out.
Cheers & Best Regards.
Dear Koh,
Thanks for letting me know. but our company is planning on to upgrade to NX11. will let our CAM team know about this. once again thanks.
Cheers & Best Regards,
You can try to add env var:
UGII_TURN_VARIABLE_B_AXIS_CONTROL=1
Best Regards!
MarcinP
