NX CAM Solution on 3 axis CNC Gear Hobbing Machine.
Any inputs or examples on How to program for a 3 axis Gear hobbing Machine..
Re: NX CAM Solution on 3 axis CNC Gear Hobbing Machine.
I've never dealt with one.
You should be able to get example code from the machine maker.
If you find out what you need, I'm guessing a custom UDE would be needed.
