NX CAM Trial MAC Address Error, cannot install
I am attempting to install the NX CAM Trial software and running into the pictured MAC Address error.  Anyone know how to remedy this?
Thanks!
Jesse
14 REPLIES 14
Re: NX CAM Trial MAC Address Error, cannot install
Oh and here's another error.  I'm running windows 7 fyi.
Anyone can help? Have same problem
 I'm thinking about buying the software, but first I want to check the test version. But how if it doesn't work, maybe support can help?
Hello
Is there a log file you can share from the LMTOOLS application that is installed?
Paul
Hello Paul
Thank u for answer.
That folders was't instaled i have only NX11.0 folder and this what is inside in the picture.
I made reinstall windows and same ;/nxcam.jpg
HI @Nevida
Do you have some virus software or firewall that could be blocking the install script from looking at your MAC Address?
Can you try the install again with virus/firewall disabled? You could check the system log straight away if it fails to see if there is any indication of what is failing.
Paul
Hi Paul.
I made how u said, i disabled antivirus and firewall and it is same like before ;/ in logs i nothink there about that installation;(
There is no folder called LMTOOLS, there should be a link to it in the start menu of Windows.
You should also find the executable in the folder UGFLEXLM.
Yea i found it, what i should do next?
