Do you mean
Reply
NX CAM Turning Simulation: No Spindle RPM during Turning Process
[ Edited ]
I'm having a problem. Why there is no value for spindle RPM during Machine Simulation? The spindle is spinning when I click play button, but under Simulate Machine panel, it shows "Speed?".
For your information, I already defined the spindle speed's RPM for this operation and all animations are works and turning process is working well as shown below pictures.
Thanks.
Zulhilmi
a) Before turning process.
b) During turning process (please note that the table is spinning).
c) RPM and Feed rate values
d) Machine Simulation panel during process (the speed is unknown)
Re: NX CAM Turning Simulation: No Spindle RPM during Turning Process
Could you please share the NC code which set the spindle active and
- which NX version?
- which controller?
Thomas Schulz
Siemens PLM
