NX CMM: Easy way to copy and pattern bolt hole circles
As the title suggests, if i have a bolt hole circle whats the best way to copy the first bolt hole and pattern it around a diameter at a given angle so that all the holes are inspected the same way and i dont have to select each hole individually?
39 REPLIES 39
Re: NX CMM: Easy way to copy and pattern bolt hole circles
Anyone?
Where exactly in the system you are making the selection?
Mark Rief
Retired Siemens
what do you mean?
i have a bolt circle made up of 40 holes.
how do i write a program so that all the holes are inspected without me having to take the time to select each and every hole?
bumps
in PCDMIS i have the ability to copy a circle and then pattern it around at a desired angle and quantity.
does NX CMM have the same ability somewhere? PATTERN doesnt seem to work for me (or at least i havent figured it out.)
bumps
I dont have a licence for or use CMM.
In normal CAM it is possible to instance an operation
Transform
cool.
but i need NX CMM solutions. thanks for trying though.
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
You can right click on the inspection path and choose transform to instance that path. Or, if you have a PMI callout with all the holes selected, you can use link to PMI and it will path all the holes. One other option is a probram called Hole Blaster that will select all the holes on the face.
