NX CMM: REVO and PH20 probe angle
Working with Modus it is very simple to define probe angles in relation to PCS, what makes the inspection working correctly regardless part placing on CMM table. (i.e. avoiding stylus collision in bore)
NX always defines the angles in relation HEADCS.
How to define probe angles in relation to PCS ?
Re: NX CMM: REVO and PH20 probe angle
I asked our CMM team about this, and should have an answer next week.
Mark Rief
Retired Siemens
If you include a comment with the string UGII_INSPECTION_5_AXIS_ANGLES=PCS in your program, the post processor will output the angles relative to the PCS
For example, manually insert a comment statement like this
$$ UGII_INSPECTION_5_AXIS_ANGLES=PCS"
Steve
It works. Is there any documentation where information like that could be found? I guess there are more useful commands that may simplify program creation.
